DIAdem
Retrieving TDMS files in Directory
In the script below, I have 2 issues with the usage of DataFileLstGet :
1. The wildcard specified is (*.tdms) which I think should only look for (.tdms) files, but it is also picking up (.tmds_index) files,
     I am temporarily filtering this out by checking for the file extension length as four.
2. The function only returns that there are 2 tdms files in the directory pointed to, while in reality I have more than 2 files in this directory.
Can anyone give me an idea of what the issue could be ?  I am using Diadem version 10.2 Base Edition, VB script engine is 5,5,0,5207.
Thanks.
Option Explicit
Dim intCount
Dim ExcelFilename
Dim TDMSFilename
Dim Ret
Dim FileExt
Dim FileExt1
Dim NumFiles
FileExt1 = "TDMS"
Ret = PathNameGet("TDMSFiles Location", "D:\MFT\datamine\pmm\testresults\")
Call DataDelAll(1)
If FilEx(OutPutPath & "*.TDMS") Then
Call DataFileLstGet(OutPutPath & "*.TDMS")
'  Call MsgBoxDisp (DataFileLstLen)
  For intCount = 1 to DataFileLstLen
'  Call MsgBoxDisp (DataFileLst(intCount))
    FileExt = NameSplit(DataFileLst(intCount), "E")
'  Call MsgBoxDisp (FileExt)
'  Call MsgBoxDisp (Len(FileExt))
    FileName = NameSplit(DataFileLst(intCount), "N")
    If  Len(FileExt) = 4 Then
        TDMSFilename = OutPutPath & DataFileLst(intCount)
        Call DataFileLoadSel(TDMSFilename,"TDMS","*/*","Load")
        ExcelFilename = OutPutPath & FileName & ".xls"
        Call ExcelExport(ExcelFilename,"", 0, OutPutPath & "EXCEL.STP")
        Call DataDelAll(1)
    End If
  Next
Else
  MsgBoxDisp("No TDMS files found")
End If
Message 1 of 9
(5,612 Views)
Hello kade!
Have a look in help for the 'DataFileLstGet' command. The command will find all 'sub' (binary) files to ONE 'master' file (TDM/TDMS) and doesn't work like a DOS 'dir'!!!
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
Message 2 of 9
(5,611 Views)
try this Code instead:
Option Explicit
Dim s
Dim oFSO
Dim oFolder
Dim oFiles
Dim oFile
Dim Ret
Dim ExcelFilename
Dim TDMSFilename
Call DataDelAll(1)
Set oFSO = CreateObject("Scripting.FileSystemObject")
Set oFolder = oFSO.GetFolder(OutPutPath)
For Each oFile in oFolder.Files
  ' Do-It-Yourself Extension Filter
  If UCase(NameSplit(oFile.name, "E")) = "TDMS" Then
    TDMSFilename = OutPutPath & oFile.name
    Call DataDelAll(1)
  End If
Next
Matthias Alleweldt
Twigeater?
Message 3 of 9
(5,608 Views)
Thanks Matthias.
Still got a few issues:
1. It still only finds one TDMS file, eventhough I have 2 in my testresults directory.
2. The excel file is not being created correctly, it tells me the file is corrupt, this seems to also happen with my version of the script which leads me to beleive my excel maybe acting funny.
Message 4 of 9
(5,605 Views)
Hello kade!
I tried with a directory with 4 files. All were found! You can add a MsgBox before the extension filter to see a complete file list.
Matthias
Matthias Alleweldt
Twigeater?
Message 5 of 9
(5,603 Views)
Ok looks like the export is working now, but the file being created is not a good excel file. I get the error "file format is not valid"
any ideas ?
Kunle.
Message 6 of 9
(5,587 Views)
Hello Kunle!
I wrote my own DIAdem Excel export functions years ago so I'm not familiar with the funny build in functions. I recommend to start a new thread with this issue.
Matthias
Matthias Alleweldt
Twigeater?
Message 7 of 9
(5,567 Views)
i narrowed it down to a diadem general error, which is not obvious what the problem is. EXCELStat retruns "100". any ideas ?
Message 8 of 9
(5,559 Views)
Hello Kunle!
Error 100 is always beloved in DIAdem and absolut expressionless Smiley Wink! Or do you expect errors?
One possible reason for you problem could be that you already have opened the output file in Excel. Excel always opens files in exclusive mode.
Matthias
Matthias Alleweldt
Twigeater?
Message 9 of 9
(5,557 Views)
