DIAdem
Report values interchanged
Just enquiring if anyone has had a report generated in Diadem and every 7 has been swapped with the 9 and vice versa.
I also saw a number on the report in an incorrect place.
I was running a vbs script which has worked fine 1000 times, but for one occasion it decided to change the numbers around.
I repeated the script and then it corrected itself.
Should I be refreshing the script as it runs more often?
Not too good if a customer sees the results, then you have to revise later.
Anyone had it similar?
Jim
(5,023 Views)
Hi Jim,
For what it's worth, I have never heard of this symptom in the nearly 15 years I've been supporting DIAdem.  I wonder if perhaps this might have something to do with the video card or OS settings on that computer.  You might keep an eye out for this sort of symptom in Excel or other applications on that computer that show numbers.
If you can reliably reproduce it, please send us the recipe, but for now I'm not thinking DIAdem is the prime suspect.
Brad Turpin
DIAdem Product Support Engineer
(5,000 Views)
