DIAdem
Replace NoValue values in channel group
I have a channel group containing multiple channels; some channels are numeric and some channels are text. Each channel has several NoValue values. Depending on the channel format, I would like to convert those NoValue values into either 0 (for numeric) or "" (for text). ChnNovHandle can do this job, although I am not sure why it requires 2 channels for input. Instead of calling many ChnNovHandle methods for each channel, is there any better way to apply this method for a whole group with selective replacement values for channels of different format?
Thank you.
(3,999 Views)
Accepted by topic author levan8421
You can use the second channel in Process NoValues analysis function as a control channel.
The control channel will be searched for NoValues and if found, NoValues will be replaced / deleted / interpolated in the control- (x-) channel and all y-channels at the same position.
If you don't need a control channel just select "Only process one channel" option.
NoValues in general are meant to replace numeric values and not text values (quote: "A Novalue is a numeric value..."):
http://zone.ni.com/reference/en-XX/help/370858N-01/varoff/nv/
So when selecting a text channel which includes "novalue" strings, Process NoValues analysis function does not find any NoValues because they have the wrong data format.
As an alternative you can use a Calculator function to replace all "novalue" strings like this:
ch("[3]/StatisticsText") = IIF(lcase(ch("[3]/StatisticsText"))="novalue","",ch("[3]/StatisticsText"))
If you want to iterate all channels in a specific group, you can put both Process NoValues and the Calculate function in a script and select them depending on the channel data type:
dim oChn, oTextChn
for each oChn in Data.Root.ChannelGroups(3).Channels
  if oChn.DataType = DataTypeChnString then
    set oTextChn = Data.Root.ChannelGroups(3).Channels(1)
    Call Calculate("A = IIF(LCase(A)=""novalue"","""",A)", Array("A"), Array(oTextChn))
  else
    Call ChnNovHandle("[3]/Res_Noise_1", "[1]/Speed", "SetValue", "X", 1, 1, 0)
  end if
next
(You can use the example_data.tdm file for my example and replace some values of the StatisticsText channel with "NoValue")
Christian
CLA, CTA, CLED
(3,965 Views)
