DIAdem
Quit/Exit/Kill script from included script
i got a problem. In main script im including secondary script, in which im calling autoquit. The secondary script returns to main script and continue executing the rest of commands in main script.
How can i kill the script in included scripts?
Main.vbs
LogfileWrite "start"
Call ScriptStart(CurrentScriptPath & "Secondary.vbs")
LogfileWrite "im still living"
Secondary.vbs
LogfileWrite "im in and dying"
autoquit
LogfileWrite "i will not execute this command"
When i run Main.vbs, i got following result:
start
im in and dying
i am still living
(6,019 Views)
You can use this in a subscript:
call Err.Raise(1,"","")
Regards
Christian
CLA, CTA, CLED
(6,003 Views)
I tested it and it has the same behavior as autoquit. it kills following instructions in a subscript, but returns to main script and continue.
(5,997 Views)
Accepted by topic author Lukas_Doubek
Sorry I misunderstood your question 🙂
I'm not sure if there is anything like this.
The only workaround I know is creating a global variable with globaldim command, set this variable inside the subscript when it's cancelled and check it in the calling script.
Main script:
call GlobalDim("Cancelled")
Cancelled = false
call ScriptStart(CurrentScriptPath & "SubScript.vbs")
if not Cancelled then
	'continue here if sub script was not cancelled
	call MsgBox("End")
end if
Sub script:
Cancelled = true
Christian
CLA, CTA, CLED
(5,987 Views)
Yep, this is the solution i was thinking about as well, but i wanted to know if there is some "ultimate autoquit" function 🙂
thanks
(5,979 Views)
I would use
err.raise
like sugested, because it is the default VBS way to transport errors.
Main.vbs
on error resume next
if 0 <> err.number then
  LogfileWrite "Error occured in Secondary: " & err.Description
end if
on error goto 0
Secondary.vbs
call err.Raise(100, currentScriptName, "Secondary failed")
(5,959 Views)
