DIAdem
Programatically set flags in a DIAdem View
Is there a command to set flags for a 2D axis system in a view? I would like to automate the process of setting flags for a curve, copying the points, and creating a report with a graph of the copied data and a table of that data. I can do the report I just need to be able to set the flags prgramatically once the users sets the band cursors where he/she wants.
AJL
(3,572 Views)
Hi AJL,
Currently it is not possible to set VIEW flags via script. But, if your customer has selected the band width you know all necessary parameters.
View.ActiveSheet.Cursor.X1
View.ActiveSheet.Cursor.X2
With pno you can determine the row in a data channel with contents closest to a given value. Example:
iRowStart = pno(NameOfXChannel, View.ActiveSheet.Cursor.X1)
iRowStop = pno(NameOfXChannel, View.ActiveSheet.Cursor.X2)
Then you can use DataBlCopy to copy the selected area.
Greetings
Walter
(3,569 Views)
Thanks, that does just what I need.
(3,566 Views)
