DIAdem
Problems with Calculator & Variables
When calling the calculation for doing the following operation, the message "Ch(0): invalid vector matrix" appears.
Does anyone has any solution? How can I use my variable in the Calculator?
I would like to erase all the negative values from channel 6 of each group respectively (in any proceeding I will have different number of groups,this is why I am using this variables.)
Dim indexgroup,sChnNo, sGrpNo
for indexgroup=1 To GroupCount step 1
Call GroupDefaultSet(indexgroup)
sGrpNo= str(cnoxget(indexgroup,6))
Call FormulaCalc ("Ch('sGrpNo'):=Ch('sGrpNo')+(Ch('sGrpNo')<=0)*NoValue")
sChnNo= str(cnoxget(indexgroup,2))&"-"&str(cnoxget(indexgroup,GroupChnCount(indexgroup)))
Call ChnNovHandle (cnoxget(indexgroup,1),sChnNo,"Delete","xy",1)
next
Thank you!
(3,265 Views)
Hi Leiabcn,
The formula calculator doesn't know VBS, therefore it is not possible to use VBS variables defined by DIM. But you can use the auxiliary variables L1, L2, ... or R1, R2 ...
Than your script must be modified as follows:
L1 = cnoxget(indexgroup,2)
Call FormulaCalc ("Ch(L1):=Ch(L1)+(Ch(L1)<=0)*NoValue")
next
By the way, cnoxget returns the channel number (this is not the channel index) and is from the type integer.
Greetings
Walter
(3,263 Views)
