DIAdem
Problems using SQL Wizard
I found very useful your SQL Wizard and I am working with it. It helps me to find the appropiate data for my analysis. But:
I have a problem using your SQL Wizard when loading my query to DIAdem. I have two channels named "TFIN" and "TDEB", these are time channels and their format should be hh:mm:ss but when I load them it appears as 30/12/1899 hh:mm:ss.
How can I change these "30/12/1899" to "00/00/00" or how can I eliminate them?
Thank you very much in advanced.
Núria R.
(3,232 Views)
Hi leiabcn,
The simplest way to remove the unwanted (and inaccurate) date information is to execute a FormulaCalculator expression, either interactively or programmatically, using the RTP() function.  For example, from a VBScript you can execute the following code to remove the date information from a channel called "FileDate" which is contained in the 1st group in the Data Portal:
L1 = CNo("[1]/FileDate")
Call FormulaCalc("Ch(L1):= RTP(Ch(L1),'h')*3600 + RTP(Ch(L1),'n')*60 + RTP(Ch(L1),'s')")
This works because the DIAdem date/time is stored as a DBL counting the number of fractional seconds since 0 AD.
Ask if you have additional questions,
Brad Turpin
DIAdem Product Support Engineer
(3,222 Views)
