DIAdem
Problem with a sort function under Diadem 9.1
Hey,
I have a problem with the CHNMULTIPLESORT function.
I have two channel´s which contains the following values.
Channel 1     Channel 2
1                    1
2                    1
3                    1
1                    2
2                    2
3                    2
1                    3
2                    3
3                    3
if I use the CHNMULTIPLESORT with channel1 and channel2
the result is:
x_sort         y_sort
1                 3
1                 1
1                 2
2                 3
2                 2
2                 1
3                 2
3                 3
3                 1
but I expected
x_sort         y_sort
1                 1
1                 2
1                 3
2                 1
2                 2
2                 3
3                 1
3                 2
3                 3
Is the a script which repairs the bug?
(3,564 Views)
Hello lai!
DIAdem just use Channel1 for sorting. If there are equal values in this channel the result is unpredictable.
Unfortunately there is no alternativ. A workaround (depending on the value ranges of the two channels) is to generate an additional temporary channel for sorting. One approach is to multiply the values of Channel1 with a constant value bigger than the biggest Value in Channel2 and add the corresponding Channel2 value to this. Note: This works only for positiv values in both channels!
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(3,552 Views)
Hi lai,
You may want to consider creating a new "Sorted Values" group and sending each set of 3 rows from channel 2 to a new channel in this new group.  It depends what you want to do with this data.  If you want to plot each set of 3 rows as a different curve on a graph, then this would be the right approach.  If you want to calculate statistics on each set of 3 rows, then you don't have to do this (nor the sorting).
If you just want to see the data displayed this way in a table, then I'm afraid you're going to have to use a VBScript to do the sorting cell by cell.  The easiest way to do this is to use a bubble sort algorythm, since you can run it once for the channel 2 values and a second time for the channel 1 values and get the two-level sorting that you're after.
Will you ever need to do this with more than 2 channels?
Brad Turpin
DIAdem Product Support Engineer
(3,543 Views)
