DIAdem
Problem in DIAdem DAC Script-processing
Se description and DAC-schema in attachments !
Regards
Henrik
Message Edited by Support on 02-20-2007 01:43 PM
(3,313 Views)
Hi Henrik,
Currently we have no idea why this behavior occurs like you described. That's something we have to look into. But we have a workaround. You can use a separate clock block for each DAC script block. That works fine in our tests. Attached you find your modified example. I hope it can help you.
Greetings
Walter
(3,276 Views)
