08-10-2005 08:27 AM
08-11-2005 05:21 AM
Hi Maxime,
Did you check whether the file is opened by another application ? If you already checked this, please send one of the files so that I can check whether there is a general problem.
One thing I have seen in the past is that files have the extension xls but are csv files internally. The Excel import is meant to import the binary Excel xls format. If you provide one of the files I can check it for you.
Andreas
08-11-2005 09:21 AM
08-11-2005 10:33 AM
Maxime,
I looked into the file and its really a CSV file using tabs as delimiter. You could read this file with the ASCII import Wizard instead of the Excel import. See the picture below to see how the data looks like in DIAdem.
If you can use DIAdem 9.1, then DataPlugins could be an alternative. Your file format looks pretty clear so it would be easy to create a DataPlugin to read your files. With that you could drag&drop the files into DIAdem and all data and descriptive elements (e.g. the THD values) would be available without effort.
Please let me know which option you prefer
Andreas
08-17-2005 09:42 AM
