DIAdem
Plugin Script for DAT File with Multiple Channel Rows
So, I'll attempt to explain this the best that I can.  I have a *.dat file that we have written a data plugin to handle importing our particular data file type and identify header properties, channel descriptions, channel units, channel names, and then associated data.  However, certain files that I would like to read in will have a block of data with a set of channel names/units and then if our data user added a channel later we get another block of data with a new set of channel names/units.  I've attached a sample of the data which I've removed most of the columns and actual data but still provided the format that it's in.  I've changed the data file format from *.dat to *.txt to upload.
What I want to do is have DIAdem create a single channel name/unit/description row that concatenates all of the channels from multiple rows and delete the rows with extra channel names in them prior to loading in the data portal.
I currently have an Excel Macro that will match the channel names and create this format for me, but I would really like to get away from using excel as an interface for my team. If DIAdem has to call Excel in the background to export/import data, I suppose that would be okay but would prefer not if at all possible.
Any thoughts on how to do this effectively?
Thanks in advance!
Bueter
(3,671 Views)
Hi Bueter,
Have you tried creating a DataPlugin with the DataPlugin Wizard for Text Files ?
When doing so, you can tell DIAdem to ignore certain lines of your input file which, as far as I understand your problem, is what you want to do.
More info here : https://www.ni.com/en/support/downloads/dataplugins/using-the-text-and-excel-dataplugin-wizards.html
CLAMaxime -- Kudos are a great way to say thank you
(3,648 Views)
I am not sure if I got you right but I will try to draw a picture of a solution.
I am assuming your files are of medium size because you are able to read them with Excel.
So I am just parsing the file inside of the vbs code instead of using the DataPlugin string blocks which would potentially give a better performance but a more complex code.
I also assume that you are using vb code in Excel too to manipulate the content, which means the attached code will not scare you.
It is meant as a statng point for you.
Your format looks like this. So we can parse it using vbTab and vbCrLf
The attached DataPlugin code will result in DIAdem Content which I hope is somehow what you are expecting
Find zip attached including the dataplugin itself.
Hope this helps starting with your DataPlugin.
Dataplugin Code:
Option Explicit
Sub ReadStore(File)
  File.Formatter.Delimiters = vbTab
  File.Formatter.LineFeeds = vbCrLF
  dim dummy : dummy = file.GetNextStringValue(eString)
  if(1 <> instr(dummy, "vsSysTestStartDate=")) then call RaiseError() ' Not my file
  Dim grp : Set grp = Root.ChannelGroups.Add(file.Info.FileName)
  dim chOArray(1001) ' array to know the order of the channels
  ' add fix blocks with dynamic dta types
  set chOArray(1) = grp.Channels.Add("Date",eTime)
  set chOArray(2) = grp.Channels.Add("Time",eTime)
  set chOArray(3) = grp.Channels.Add("numTest1Run",eR64)
  set chOArray(4) = grp.Channels.Add("vsSysOperatorPreLogComment",eString)
  set chOArray(5) = grp.Channels.Add("vsSysOperatorPostLogComment",eString)
  call file.SkipLines(4) ' skip header, can be parsed and added as properties
  file.Formatter.TimeFormat = "MM/DD/YYY hh:mm:ss:.fff" ' set formatter for data
  dim currNrOfChannels : currNrOfChannels = 0
  dim pos, i : pos = 0
  dim leader : leader = 0
  dim currLeader : currLeader = 0
  do
    leader = file.GetNextStringValue(eI32)
    if VBNULL = VarType(leader) then
      ' empty or invalid line
    elseif leader <> currLeader then
      ' new block
      currLeader = leader
      currNrOfChannels = 5
      call file.SkipValues(9) ' Alias
      dim chName : chName = file.GetNextStringValue(eString)
      while "" <> chName and grp.Channels.count < 1000
        dim chO : set chO = nothing
        if not grp.Channels.Exists(chName) then
          set chO = grp.Channels.Add(chName,eR64)
        else
          set chO = grp.Channels(chName)
        end if
        currNrOfChannels = currNrOfChannels + 1
        set chOArray(currNrOfChannels) = chO
        chName = file.GetNextStringValue(eString) ' Next element
      wend
      file.SkipLine() : file.SkipValues(5) ' PARAMS
      for i = 1 to currNrOfChannels
        chOArray(i).properties("description").value = file.GetNextStringValue(eString)
        Next
      file.SkipLine() : file.SkipValues(5) ' UNITS
        chOArray(i).properties("unit_string").value = file.GetNextStringValue(eString)
      Next
    else
      ' data line
      pos = pos+1
      call file.SkipValues(4)
      ' fill the leading once
      chOArray(1).Values(pos) = file.GetNextStringValue(eTime)
      chOArray(2).Values(pos) = file.GetNextStringValue(eTime)
      chOArray(3).Values(pos) = file.GetNextStringValue(eR64)
      chOArray(4).Values(pos) = file.GetNextStringValue(eString)
      chOArray(5).Values(pos) = file.GetNextStringValue(eString)
      for i = 6 to currNrOfChannels ' add the dynamic numeric ones
        chOArray(i).Values(pos) = file.GetNextStringValue(eR64)
      Next
    end if
  Loop until Not file.SkipLine()
End Sub
(3,621 Views)
