DIAdem
PicpdfExport Access Violation
As of today this PicPdfExport is´nt functioning anymore. As I´m trying to execute the command "call PicPdfExport("O:\Bildmesstechnik\03Output\" & vnummer & "_Tracking")" but I keep on recieving the msg Access Violation.
DiaDem V. 9.1 and the DiaDem Pdf Export are installed and working.
(3,531 Views)
Do you have different DIAdem versions on your computer?
If you install DIAdem 9.1 and DIAdem 10 on one computer, only one of the versions can print to PDF files. If you want to print in the other DIAdem version, delete the DIAdem PDF Export printer in the Windows Control Panel before you launch DIAdem. DIAdem then adds the printer when it launches. You need administrator rights to install this printer.
Hope this helps
Winfried
(3,528 Views)
Did the trick!
Guess it´s not going to be my last time entering this forum.
(3,519 Views)
