01-18-2016 08:53 AM - edited 01-18-2016 08:54 AM
we are using Windows Common Controls from Microsoft, like MSComCtlLib, based on DLL like msconct2.ocx in 32-bit DIAdem dialogs as Active X objects. The controls are not recognized and are not usable by 64-bit DIAdem.
Do you know a way to avoid the issue, like start dialogs with 32-bit VBScript engine?
Any appropriate 64-bit Controls?
Other siggestion?
01-19-2016 02:20 AM
Hello Sasha,
I suppose the OCX is compiled for 32-bit, so thats probaly the cause why it is not working in 64-bit.
You could start a dialog in the 32-bit version with the function "ExtProgram" when you start DIAdem 32-bit with a parameter as a startscript. The startscript would run the dialog and when finsihed close the DIAdem 32-bit instance. You probably have to load and save some kind of data in the 32-bit version to exchange information with the 64-bit instance.
Command: ExtProgram - DIAdem 2011 Help - National Instruments
http://zone.ni.com/reference/en-XX/help/370859J-01/comoff/extprogram/
That anyone could help you with alternative controls, it would be good to know, what do you need those controls for?
Is there a 64-bit version for that library. Since that question (Any appropriate 64-bit Controls?) rather seems a Microsoft/non-DIAdem one, perhaps you should seek help for that part in a forum specialized with that.
Of course I try to help you along in all DIAdem related stuff.
Christoph
01-20-2016 03:53 AM
Thank you Christoph,
we are using "MSComCtlLib.TreeCtrl.2" and "MSComCtlLib.ImageListCtrl.2" from 32-bit mscomct2.ocx. I have not found any 64-bit replacement for that OCX. So we will use firstly 32-bit DIAdem and will rewrite our dialogs to not use such a controls.
