DIAdem
Multiple X axes in DIAdem 9.1
Is it possible to have multiple X-axis scales for a 2-D plot in DIAdem 9.1?
I have no problem with multiple y axes but I would also like multiple x axes as well.
Tom
(4,423 Views)
Hi Tom,
The direct answer is No.  You can fake it pretty well, though, by overlaying multiple 2D graph objects.  Use the position properties in the dialog to make the exact overlaying easier.
Let us know if you need further help with this,
Brad Turpin
DIAdem Product Support Engineer
(4,400 Views)
This is disappointing. I have several plots I wish to overlay, with a shared single y-axis and independent x-axes. I wish to do this in the View worksheet, and quickly/interactively. I don't want to be hacking around in Report.
Thoric (CLA, CLED, CTD and LabVIEW Champion)
(3,837 Views)
Hi Tom,
Multiple X axes are not supported anywhere in DIAdem 2012, so that's a dead stop.  If you want to overlay multiple curves in VIEW that have different X values, you will need to rescale those X values.  If you're plotting waveforms, this is as easy as multi-selecting the set of N channels you want to change in the Data Portal and editing the waveform start offset property, which will make the property value change you entered once to all N channels selected.  If you have N Y channels that share an X channel, then you just need to rescale the one X channel once with the Linear Scaling function in ANALYSIS.
Brad Turpin
(3,818 Views)
