DIAdem
Multiple File Selection
Hi
     I am planning have Multiple Selection enabled dialogue box ....below is the code which I am using , but i am not able select multiple files. The same code(except ".X.") in VB environment works really fine
     MSComDlg2.X.Flags = cdlOFNAllowMultiselect Or cdlOFNExplorer
     MSComDlg2.X.ShowOpen
Please help me on this...
Warm Regards
Andrew
(3,473 Views)
Hi Andrew,
I recommend you use the native DIAdem FileNameGet() dialog box, which does have a multiple file selection option.  See the attached code below.
Brad Turpin
DIAdem Product Support Engineer
(3,462 Views)
