DIAdem
Multi Plot
Hi everyone,
I am currently working with DIAdem and I would have some newbie questions.
Call PicLoad("Template")
Call GraphObjNew("2D-Axis","2DAxis1")
Call GraphObjOpen("2DAxis1")
  Call  GraphObjNew("2D-Curve","New_Curve") 'Creates a new curve
  Call GraphObjOpen("New_Curve")            'Opens the curve object
  D2CChnYName      = "GroupName/ChannelName"
  Call GraphObjClose("New_Curve")
D2AXISTOP        = 9
D2AXISBOTTOM     = 40
D2AXISLEFT       = 15
D2AXISRIGHT      = 40
Call GraphObjClose("2DAxis1")
Call PicUpdate
 When I copy paste this twice and change the Channel Name, the previous plot is erased by the new plot. Would you know how to fix this?
Also I was wondering how to change the marker. By mouse it is possible to select the cross marker but I do not know how to do it by script. The only thing I know is that I should put "cross" somewhere, but have no idea of the right command.
Message 1 of 15
(7,816 Views)
Bump.
I am not interested in placing the second plot next to the first one, but in placing the second courb in the first plot, with the first courb.
I hope someone will help me out !
Message 2 of 15
(7,801 Views)
Accepted by topic author Near3
  Call  GraphObjNew("2D-Curve","New_Curve2") 'Creates a new curve
  Call GraphObjOpen("New_Curve2")            'Opens the curve object
  D2CChnYName      = "GroupName/ChannelName2"
  Call GraphObjClose("New_Curve2")
D2AXISTOP        = 9
D2AXISBOTTOM     = 40
D2AXISLEFT       = 15
D2AXISRIGHT      = 40
Call PicUpdate
Can you try this?
Basically you just want to have a new Curve and not reload the whole template (PicLoad("Template")) or change an Axis (the part with the axis ;)), so you wouldn't want to repeat that code.
4th of July is generally a slow response day on the forum..
I wonder why... 😉
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 3 of 15
(7,792 Views)
That worked !
Thank you very much 🙂
Message 4 of 15
(7,787 Views)
No problems!
Kind Regards,
Message 5 of 15
(7,783 Views)
Oh actually we forgot my second question about the marker. Would you know what command allows to use different markers?
Message 6 of 15
(7,779 Views)
Actually, that's my mistake.
I focused on the second post 🙂
Here an adapted version:
D2AXISTOP        = 9
D2AXISBOTTOM     = 40
D2AXISLEFT       = 15
D2AXISRIGHT      = 40
Dim o2DLineExtensions, o2DAdditionalMarker
Set o2DLineExtensions = Report.ActiveSheet.Objects.Item("2DAxis1").Curves2D.Item("New_Curve").Shape.Extensions
Set o2DAdditionalMarker = o2DLineExtensions.Marker
o2DAdditionalMarker.Type        = eMarkerCross
Call PicUpdate
Are you familiar with script recording?
If not, here's the information about it:
http://digital.ni.com/public.nsf/allkb/B769AE10EDB656D28625692D00583166?OpenDocument
It can help alot when starting to write scripts.
Kind Regards,
Message 7 of 15
(7,771 Views)
Thank you for your rapidity.
If I copy paste what you wrote, DIAdem tells me that : Variable is undefined : 'Report'
I tried to use the script recording as you advised me, and manually removed the line then put the cross markers, but nothing has been written between the moment I started it and the moment I stopped it. It sadly seems that what's going on in the report section is not always taken into account by the script recording 😞
Message 8 of 15
(7,767 Views)
Did you read through the CTRL-A remarks?
Hmm, the Report should automatically refer to your Report class.
Which version of DIAdem are you using?
Kind Regards,
Message 9 of 15
(7,763 Views)
The REPORT object was first released in DIAdem 2012.
Brad Turpin
DIAdem Product Support Engineer
Message 10 of 15
(7,749 Views)
