DIAdem
MQTT and RabbitMQ support
Hi Group,
In review of the DIAdem help, found that there was a object for MQTT.   (Message Queue Telemetry Transport Protocol) for my 2018 DIAdem version.
This appear like this will allow DIAdem to communicate with RabbitMQ.    Is this possible, and are their any examples of this.
Paul
(3,474 Views)
Accepted by topic author Pesmith8
Dear Paul,
Have you seen this documentation?
Object: MQTT
http://zone.ni.com/reference/en-XX/help/370858P-01/diamisc/objects/mqtt_objects_mqtt/
(3,448 Views)
Additional details:
This is a note for the user Community about the nice MQTT BiDirectional Messaging system
The help in DIAdem could use some improvement.  Below is a script that will work with a Local install of Mosquito Broker.
In order to help with understanding how the MQTT works, I would suggest strongly that the youtube link be viewed at
https://www.youtube.com/watch?v=VSwu-ZYiTxg     It gives a good background for the MQTT system.
The script below will both post and read topics from the MQTT Mosquito broker.
'-- VBS script file
'-- Created on 05/25/2019 20:08:51
'-- Author:
'-- Comment:
Option Explicit  'Forces the explicit declaration of all the variables in a script.
Dim MQTT
Sub SFD_WriteChannel(ChannelNumberP, ParamP, DataP, ErrorP)
  Call MQTT.WriteString(ParamP, DataP)
End Sub
Sub SFD_Init(DeviceParam1V, DeviceParam2V, ErrorP)
  Set MQTT  = CreateMQTT(DeviceParam1V)
  MQTT.Connect
End Sub
dim sError
dim sTemp : sTemp = ""
call SFD_Init("127.0.0.1", "test01", sError)
call MQTT.Subscribe("test01")
'call SFD_WriteChannel("127.0.0.1", "test01", "Message0333", sError)  ' Worked ! to post to topic on Broker
dim smsg : smsg = ""
dim i
for i = 0 to 1000
  sTemp = ""
  sTemp = MQTT.ReadString("test01")  ' this works but also every time it reads msg the same message appears even if it is old.
  ' would then need to put in a date/time for message. so that know that have already received it, so that can only look for new ones.
  ' also does not have any memory of past msgs Must then monitor the topic to make sure that receive all the messages.  For use for Datavisor packages.
  ' would want to have a fairly fast monitoring system for listening to this topic.
  ' Maybe would want this to be a python program using paho,where would listen to topic, and then put into a log file as it comes in. Then can parse this as needed.
  ' would
  If isEmpty(sTemp) Then
    sTemp = ""
  end if
  logfilewrite i & " " &sTemp
  pause 0.5
'call SFD_ReadChannel("127.0.0.1", "test01", smsg, sError)
next
Sub SFD_ReadChannel(ChannelNumberP, ParamP, DataP, ErrorP)
  Dim sTemp
  Set MQTT  = CreateMQTT(ChannelNumberP)
  sTemp = MQTT.ReadString(ParamP)
   DataP = NoValue
  Else
    If sTemp <> "" Then
      DataP = CDbl(sTemp)
    Else
      DataP = NoValue
    End If
  End If
End Sub
(3,210 Views)
