DIAdem
Looping through channels and groups in VB
I am trying to setup a format to loop through groups and run an identical function on the channels, where the channel names are the same. I cannot find an easy format to perform this under. Here is the example code I am trying to get to work:
dim intMyChnla, intMyChnlb, intMyChnlc, intMyChnld
dim indexgroup, sGrpName
for indexgroup=1 To GroupCount ' step 1
sGrpName = GroupName(indexgroup)
intMyChnla = CNo("sGrpName/ABCAhIn")
intMyChnlb = CNo("sGrpName/Total_ABCAhIn")
intMyChnlc = CNo("sGrpName/ABCAhOut")
intMyChnld = CNo("sGrpName/Total_ABCAhOut")
Call FormulaCalc ("Ch('sGrpName/Calc_Total_AH_Throughput') := Ch('sGrpName/intMyChnla') + Ch('sGrpName/intMyChnlb') + Abs(Ch('sGrpName/intMyChnlc')) +Abs(Ch('sGrpName'/intMyChnla'))")
the following calculation works in the Calculator, but I have to change the 20 number to correspond to the Group.
Ch('[20]/Calc_TotalAhThroughput'):= Ch('[20]/ABCAhIn') + Ch('[20]/Total_ABCAhIn') + Abs(Ch('[20]/ABCAhOut')) +Abs(Ch('[20]/Total_ABCAhOut'))
Thanks for the help.
Rich
(4,265 Views)
Hello Rich,
I think I understand why it doesn't work as expected : In your call to Formulacalc you write
You have set the local VBS variable sGrpName to the groupname. But within the call to Formulacal its a simple text. With that DIAdem tries to find a group named "sGrpName" which probably doesn't exist. You could write something like :
sgCommand = "Ch('#1/Calc_Total_AH_Throughput') := Ch('#1/intMyChnla') + Ch('#1/intMyChnlb') + Abs(Ch('#1/intMyChnlc')) +Abs(Ch('#1/intMyChnla'))"
sgCommand = Replace(sgCommand,"#1",sGrpName)
Call FormulaCalc (sgCommand)
The Replace function will replace the text "#1" with the group name stored in your local variable sGrpName. You may want to check sgCommand to see whether everything works right.
Andreas
(4,260 Views)
Yes, that essentially worked for me.  Thank you.
Here is what the final script looks like:
dim indexgroup, sGrpName, sgCommand
intMyChnla = CNo("ABCAhIn")
intMyChnlb = CNo("Total_ABCAhIn")
intMyChnlc = CNo("ABCAhOut")
intMyChnld = CNo("Total_ABCAhOut")
' Call FormulaCalc ("Ch('sGrpName/Calc_Total_AH_Throughput') := Ch('sGrpName/ABCAhIn') + Ch('sGrpName/Total_ABCAhIn') + Abs(Ch('sGrpName/ABCAhOut')) +Abs(Ch('sGrpName'/Total_ABCAhOut'))")
sgCommand = "Ch('#1/Calc_Total_AH_Throughput') := Ch('#1/ABCAhIn') + Ch('#1/Total_ABCAhIn') + Abs(Ch('#1/ABCAhOut')) +Abs(Ch('#1/Total_ABCAhOut'))"
Next
(4,242 Views)
