DIAdem
Logfile error
I have had the following message (see below). I have completed a considerable amount of work on 5 graphs. I've saved the TDR file. I have also renamed the tabs for each graph. I have used a / in one of the tab names - is this causing a problem? When I reload the graph layout it gives me the following error and no data is visible where the graphs were.
**** DIAdem-STARTED Version: 9.1 on 10/11/2009 at 12:02:01 *********************
70   **** Message registered on 10/11/2009 at 12:02:06
71   Loading file "C:\Program Files\National Instruments\DIAdem 9.1\LIBR\DAT\EXAMPLE.TDM" ...
72   **** Message registered on 10/11/2009 at 12:02:06
73   File "C:\Program Files\National Instruments\DIAdem 9.1\LIBR\DAT\EXAMPLE.TDM" loaded!
74   **** Error registered on 10/11/2009 at 12:04:48 [Message file:GLOBERR / Text area:1 / Text number:260]
     Error while loading. Refer to the logfile for details!
(3,587 Views)
Hello!
A '/' is a legal character in a tab name. If there is a problem with a TDR file DIAdem writes a file like 'MyLayout.TDR.log' in the same path as the TDR file. Have a look in it.
If it is possible for you please attach the TDR file to a post in this thread.
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(3,574 Views)
