DIAdem
Logarithmic Inverted Scale
Is it possible to put an Logarithmic Inverted Scale in a report ?
(5,331 Views)
Hi zebulonbg,
Please provide more information.  Are you talking about the X axis, the Y axis, or both?  Are you talking about a 2D graph or a 3D graph?  Please descibe in more detail what you would like the axis to look like-- what would be the starting value, the ending value, and the tick line values.  Ideally, you would attach a picture of the graph you want and a copy of your data set.
Brad Turpin
DIAdem Product Support Engineer
(5,307 Views)
I just want to plot in a 2D Graph a curve and to have on the Y-axis a logarithmic scale and to have the maximum of the Y-axis at the bottom and the minimum at the top of the Y-axis. This is very useful when you have to plot a profile of temperature with the pressure on the Y-axis (example from 1000 to 10 hPa on the Y-axis1).
Below, this is an example (plot with LabView)
In advance, Thank you
(5,287 Views)
Hi zebulonbg,
Thank you, it is now very clear what you want to achieve.  I think we're going to have to get creative to do this in DIAdem-- options I can think of right away include a 3D graph, the Channel Calculator, or Curve Transformations.  Would you be willing to post the data set behind that LabVIEW graph so that I can play with various graphing options and see which one works the best with the smallest effort?
Brad Turpin
(5,267 Views)
You can find data in the attach file. Thank you very much.
First column: pressure
Second column: temperature
Message Edité par zebulonbg le 12-03-2009 07:38 AM
(5,244 Views)
Hi zebulonbg,
Sorry for the delay, I was sick last week after the Thanksgiving holiday here in the US.  I created a 3D REPORT layout that displays your data the way you requested.  The first sheet is autoscaled, and the second sheet is manually scaled to be exactly what the LabVIEW graph showed that you posted.
Ask if you have additional questions,
Brad Turpin
(5,193 Views)
Thank You very much for your solution. It works very well. I just have the demo version of Diadem 11, but I make the same thing with Diadem 9.1
(5,170 Views)
