DIAdem
Load all .tdms files from filder using .vbs
I have 17 data files (.tdms) stored in local folder. In my script, now, I use --Call DataFileLoad(autoactpath&test1&".tdms","TDMS","Register") to load all files (run this command x17 times with different input :test1,test2...test17). Is any method to load automatically this data ? I want to keep my variabile name (test1,test2...) just to not modify all script.
Now, my script is kind of:
test1= InputBox("File name no. 1")
test2= InputBox("File name no. 2")
------do someting----------
Data.Root.ChannelGroups.Remove("Data")
Call DataFileLoad(autoactpath&test2&".tdms","TDMS","Register")
And so on.
Thank you in advance.
(1,269 Views)
Hi Alex_SI,
You can try this script:
dim sSearchFolder, sFileListArray, iLoop, sFullFileName
sSearchFolder  = "d:\Test\xxx\"
sFileListArray = DirLstWrite(sSearchFolder, "*.TDM", "filename", , 0, "FullFilenames")
for each sFullFileName in sFileListArray
  call Data.Root.Clear
  call DataFileLoad(sFullFileName)
  ' do something
next
Greetings
Walter
(1,263 Views)
Thank you so much. All works fine.
Could you also help me with print a report ?
Or should I open new topic?
(1,222 Views)
Hi Alex_SI,
You can enable the recording mode in DIAdem to get command for scripting like:
  • enable the recording mode
  • select script language (VBS or Python)
  • do something
  • disable the recording mode
All relevant script commands are recorded in SCRIPT
Greetings
Walter
(1,208 Views)
