DIAdem
Load Database Configurations with Startup Script
Hello, I would like to use a startup script to add a data store, open a loading configuration file, and open a browse settings file.  Basically, I want to have users point to a startup script and everything for our Database is ready to go.
I have the .urs, .tbs. and .tdl files.  What is the command to load these into diadem?
I have tried Navigator.RegisterDataProvider(MyURSlocation,False), but that causes Diadem to lockup on startup.
Any suggestions?
Thanks.
(4,408 Views)
D'oh!  I had a forward slash in the file path I sent to the RegisterDataProvider method.  The devil is in the details!
(4,349 Views)
Hi RussellSenior
You are asking for the handling of many DataStore parameters.
The *.TDL file organize the Loading Parameter Set of a DataStore. The *.TBS file is used to handle the Technical Browse Settings. The *.URS is a registration of a DataStore Definition.
Here are two areas, where the different files you pointed on are used.
At the one hand side there are the handling of the user interface of Module NAVIGAROR. All of this is handled by DIAdem Navigator itself.
    The scripting access for these objects are:
                   Navigator.Display…
        Navigator.Display.OpenDataStore()
        Navigator.Display.CurrDataStore.SetBrowseSettings
At the other hand side there exists a DataStore Object without using the interface.
        Navigator.ConnectDataStore()…
      Navigator.ConnectDataStore.SetBrowseSettings
The PropertyImportSet is used as parameter of the loading command. (Navigator.LoadData() )
To register a DataStore definition, contained in a *.URS file, please use the following script snippet:
      Navigator.Settings.RegisterDataProvider()
This line will register the DataStore for this computer. The list of all registered DataStores you will find here: Navigator.Settings.RegisteredDataStores
I hope you will be able to solve your issue with these information.
Best regards
Joerg
(4,247 Views)
