DIAdem
Is there a graceful way to cancel a Python script?
as the title says, I'm wondering if there is a graceful way to exit a python script.
Calling sys.exit / raising SystemExit always seems to trigger an error message, independently of the exit code that is passed. (I tried it with 0, 1, -1, None)
(2,031 Views)
If I understood it correctly, I think the best way is to use the return command.
def your_function():
    # Insert your code here
    return
(2,010 Views)
Hello panta1978,
unfortunately that can only be used within functions.
And execution will continue where the function was called. It will not exit the script.
When used outside of a function it is considered a syntax error.
The script won't even start.
(2,003 Views)
