DIAdem
Is a grid in DIAdem-VIEW possible?
Hi
at the moment, i use a VBS script to import files containing ascii data of two channels into DIAdem-VIEW.
How can i enable a grid in a 2D axis in DIAdem-View?
And is it possible to automatically add the channel name to each 2D axis figure in VIEW?
I cannot use REPORT, because i always need to scroll and zoom.
Manfred
(3,821 Views)
Hello Manfred,
I am assuming that ou use DIAdem 9/9.1.
If so, you can add curves to an existing VIEW layout. You can also create the whole layout from scratch. Please search for the "VIEW object" in the index of the Online-Help. The API is really easy to use.
Regarding the grid, the answer is that this is not yet possible. If you get a chance to look at the DIAdem 10 beta, you will see that it is available there.
Please ask if you have further questions.
Andreas
(3,817 Views)
Hi
Thanks for the answer.
I understand that a grid in a 2D axis in DIAdem view is not possible in V9.1.
Where can i get a test version of DIAdem V10 beta?
Manfred
(3,809 Views)
Hi Manfred, To take part in the DIAdem beta programm, please go to www.ni.com/beta, select DIAdem 10.0 as product and sign in to the beta program. A few hours later your assignment will be acknowledged and you can download the beta version. Regards, Ralf
(3,803 Views)
Hi
I tried the V10 beta. The grid is very nice.
When is V10 expected to be final, any ideas?
Manfred
(3,775 Views)
