DIAdem
Is DIAdem script with Extended Classification functionality of DIAdem Professional executable by DIAdem Base?
The Professional license adds 3D model data mapping and Extended Classification functionality to DIAdem. If I make a script that uses the 3D model data mapping functionality in DIAdem Professional it is possible to use this same script on a PC with only DIAdem Base (according to http://sine.ni.com/ds/app/doc/p/lang/nl/id/ds-263)
Is this also true for the Extended Classification functionality? Is it possible to make a script with DIAdem Professional and execute this same script on a PC with only DIAdem Base to generate a report?
Roger
(5,613 Views)
Hi Roger,
My understanding is that the VBScript you create that uses the extended classification function will work fine in DIAdem Base.
Brad Turpin
DIAdem Product Support Engineer
(5,602 Views)
