DIAdem
I16 Type Channel Contents (The value of the data type is unknown.)
Hello.
I am trying to read data of data type I16 by executing the code below in python3.
Python3 Code
raw_byte = b'\x01\x80'
t1 = np.frombuffer(raw_byte, dtype='<f2')[0]
print(t1) # result => -6e-08
The correct result should be 0.099999999999999
I16 DATA
01 80 7A 8D F3 9A 6C A8 E5 B5 5E C3 D7 D0 50 DE C9 EB 42 F9 BC 06 35 14 AE 21 27 2F A0 3C 19 4A 92 57 0B 65 84 72 FD 7F
However, the result is different from the channel content data value of the Diadem program.
Even looking at the help, I can't figure out what to do.
I am working on the 3rd day, but I can't solve it.
Please help me. ㅠㅠ
Thanks.
(1,479 Views)
I am not familiar with numpy, but if you want to read I16 I assume your format string is wrong.
I16 must be numeric between   [-32767, +32767]
Using struct (part of native python) you need to use "h" as format for I16.
import struct
i16_bigEndian = struct.unpack('>h', raw_byte)[0]
i16_littleEndian = struct.unpack('<h', raw_byte)[0]
print(i16_bigEndian)
print(i16_littleEndian)
returns
384
-32767
 depending on the endianess.
Reading the complete dataset would look like
raw_byte = b'\x01\x80\x7A\x8D\xF3\x9A\x6C\xA8\xE5\xB5\x5E\xC3\xD7\xD0\x50\xDE\xC9\xEB\x42\xF9\xBC\x06\x35\x14\xAE\x21\x27\x2F\xA0\x3C\x19\x4A\x92\x57\x0B\x65\x84\x72\xFD\x7F'
i16_bigEndian = struct.unpack('>20h', raw_byte)
i16_littleEndian = struct.unpack('<20h', raw_byte)
returning
(384, 31373, -3174, 27816, -6731, 24259, -10288, 20702, -13845, 17145, -17402, 13588, -20959, 10031, -24516, 6474, -28073, 2917, -31630, -641)
(-32767, -29318, -25869, -22420, -18971, -15522, -12073, -8624, -5175, -1726, 1724, 5173, 8622, 12071, 15520, 18969, 22418, 25867, 29316, 32765)
(1,428 Views)
