DIAdem
I have some questions about VBScript Functions
Hi Community
I need to load selected variables of .dat file and how to interpolation 2 channel(data and variable) that different sampling time
(e.g. 10hz, 100hz) to use VBScript.
also I wonder how to plot data to use VBScript.
really want to know those.
Thanks.
(2,548 Views)
What I understand is that you want to plot two data which have a different sample rate.
I guess the number of the data is different.
You can use Resameple Mode as below. You can re-sample data so you can match the number of the data.
You should look into how to use resample mode. You might want to search the examples on DIAdem.
(2,523 Views)
