DIAdem
I have a problem with MS Access and SQL over ODBC
Hello Forum!
i have the following problem, i use a MS Access database and i want to query datasets from a table with 1100000 datasets. I had configure a System-DSN using the standart "Microsoft Access Driver (*.mdb)". Now i execute the following code
  T1 = "select test.x, test.y from test"
  Call SQL_ExecDirect("T1")
  Call SQL_BindChannel("x","x","n")
  Call SQL_BindChannel("y","y","n")
Normally all the datasets must be in the channels, but there are only 200000 datasets. furthermore i use diadem in the version 10.00.2541 but only the evaluation version and MS Access 2003 version 11.0. Are there any limitation with the ODBC-SQL-Dataquery?
with best regards
Markus Schmid
(3,241 Views)
Hello Markus,
Because of performance the internal buffer size contains the first 200000 records. To read until the end of the table we added the additional command "SQL_FetChNext".
Here is an example for the commands you are looking for:
Do While (SQL_Next)
  call SQL_FetChNext()
Loop
Greetings
Walter
(3,233 Views)
