DIAdem
How to select specific rows in a data table based on a condition to delete it in DIAdem ?
I have a group with several channels that when the value in one channel is less than a certain value, I want that row and all the same rows in the other channels deleted.
Is there any way to programmatically achieve this through a script on DIAdem 2021?
(4,041 Views)
Hi joshilpa,
Sure, this is a pretty typical task in DIAdem, and it proceeds in two steps:
1) Identify all the rows you want to delete by setting them to NoValue in one channel
2) Deleting the same rows in other channels that have the NoValue in that one channel
Step 1) can be accomplished with the Channel Calculator or with the Event finding dialogs in ANALYSIS.
Step 2) always uses the ChnNovHandle() command.
If you have trouble implementing this in script based on the above, please post a sample of your data file and a description of the rows you want to delete, and I can send you a quick script that executes both steps.
Brad Turpin
Principal Technical Support Engineer
NI
(4,009 Views)
Hi Brad,
Could you please help implementing the same with a script. Pfa an example where I want to delete all rows corresponding to channel Power less than 40kW.
(4,005 Views)
Hi Brad,
I tried writing the below python script but I do not get the desired results with it , could you please suggest what could be the issue here?
sOutput =""
oMyChannels = dd.Data.GetChannels("[1]/*")
for oMyChn in oMyChannels:
    sOutput = sOutput + "\r\n" + oMyChn.Name
ch("[1]/x")=IIF(ch("[1]/Power")>40,ch("Power"),NoValue)
ChnNovHandle(x, sOutput ,"Delete", "X", 1, 0)
Alternatively tried adding channel using below method but it doesn't evaluate on all rows:
#Formula 1
dd.Data.Root.Channelgroups.Item("Example").Channels.AddCalculationChannel("x", "= IIF(ch(""Power"")>40,ch(""Power""),NoValue)",dd.DataTypeChnFloat64,10)
# Formula 2
dd.Calculate("Ch(""x"")=IIf( Ch(""Power"" > 40),Ch(""Power""),NoValue)")
(3,982 Views)
Accepted by topic author ebenellis
Hi josh,
It's easier to call the dd.Calculate() command if you define its 3 parameters beforehand as variables.  If you define the CalcChannels you want to remove rows from as a DIAdem ElementList, then create a Channel object variable for the row-defining PowerChannel, you only have to set the PowerChannel rows to NoValue.  You can remove the matching rows from all the CalcChannels and the NoValue rows from the PowerChannel at the same time and spare yourself the loop.
DataFilePath = r"C:\Users\Public\Documents\National Instruments\DIAdem 2021\Data\Example.tdm"
dd.Data.Root.Clear()
dd.DataFileLoad(DataFilePath, "TDM")
Group = dd.Data.Root.ChannelGroups(1)
PowerChannel = Group.Channels("Power")
CalcChannels = dd.Data.CreateElementList()
CalcChannels.AddElementList(Group.Channels)
CalcChannels.Remove(PowerChannel)
dd.ChnValExpand(PowerChannel)
Symbols = ["P"]
Formula = "P = IIF(P > 100, P, NoValue)"
dd.Calculate(Formula, Symbols, [PowerChannel])
dd.ChnNovHandle(PowerChannel, CalcChannels, "Delete", "X", 1, 0)
Brad Turpin
NI
(3,965 Views)
Thank you Brad for proposing an efficient solution & detailed explanation!
(3,913 Views)
