DIAdem
How to read and create TDM Files in a Java Application?
I want to read and write TDM-Files in a Java-Application.
I found the TDMHeaderWriter for Java, that can write TDM-Files, but the reading part is still missing.
Perhaps anyone knows an equivalent in Java to the TDM C DLL and the TDM C Header DLL?
Thanks Verena
(5,915 Views)
Hi Verena,
the TDM Header Writer is also available for Java:
TDM Header Writer Java API
Unfortunately there is no Java equivalent for the TDM C DLL
Stefan
(5,911 Views)
Hi Stefan,
thanks, I already tried the TDM header Writer Java API.
Unfortunatelly it is only half the battle, because I've also to read TDM files.
Verena
(5,893 Views)
Hello Verena!
With a thin C layer it should be no problem to connect the TDM C DLL to Java via JNI. The main part could be done in a few hours but isn't a out-of-the-box solution.
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(5,890 Views)
Hi Matthias,
that's exactly the solution I'm working on now. :smileywink:
Verena
(5,885 Views)
Cool Smiley Happy
Can you please give me feedback on this project if you have finished it?
Matthias
Matthias Alleweldt
Twigeater?
(5,874 Views)
