DIAdem
How to multiply channel by variable
I have a time stamp which is not real time, but next number. I know the interval (like 1 or 10 seconds) of measurements. So, I'm converting this to normal time. In this case I need to multiply this channel by specific interval. This is easy, because you can multiply channel by a constant like below:
  Call ChnCalculate("Ch(""[2]/Seconds1"")= Ch(""[1]/#"") * 1")
  Call ChnCalculate("Ch(""[2]/Minutes1"")= Ch(""[2]/Seconds1"") / 60")
  Call ChnCalculate("Ch(""[2]/Hours1"")= Ch(""[2]/Minutes1"") / 60")
But how to do this using variable? Let's say we have variable s_interval and we want to put this variable instead of multiply it by constant .
Ch(""[1]/#"") * 1")
Do you know how to do this?
Piotr
(4,902 Views)
Accepted by topic author Piotr_Samek
Hi Piotr,
You can define it like this:
dim dFactor
Call ChnCalculate("Ch(""[2]/Noise_1"")= Ch(""[2]/Noise_1"") / " & dFactor)
But I would prefer a DIAdem function for this calculation because it is faster using a well defined function than the calculator.
dim dFactor, dOffset
dFactor = 10
dOffset = 0
Call ChnLinScale("[1]/Time", "[1]/Time", dFactor, dOffset)
or if you use the channel object:
dim oChn, dFactor, dOffset
set oChn = Data.GetChannel("[1]/Time")
dFactor = 10
dOffset = 0
Call ChnLinScale(oChn, , oChn, dFactor, dOffset)
Greetings
Walter
(4,881 Views)
Thank you Walter! It works perfectly 😉
Piotr
(4,877 Views)
