06-27-2011 09:59 AM
I am exporting a series of 3D plots from DIAdem REPORT to PowerPoint (I am using DIAdem 2010) and can't find a way to export a chart with no border (i.e. a chart that floats on the page, with no defined border around the drawing object).
Is this a setting somewhere in DIAdem?
Thanks!
06-27-2011 07:42 PM
David,
I might be stating the obvious here, but in REPORT when you go to the "Settings" menu, select "Layout Setup > Layout Parameters"
There, disable the "Frame".
That should do the trick for you.
Let me know if that helped,
Otmar
06-28-2011 07:29 AM
Otmar,
Yes, it does. Sorry - coming from Excel I had assumed it must be a property of the chart itself, not of the whole drawing area within REPORT.
Thanks for the fix! As you can tell, I am still learning DIAdem.... 🙂
