DIAdem
How to close external programs?
Hi there,
in vbs is a command "ExtProgram(ExtProgramName, ExtProgramArg)" to start external programs. But how to  close external programs when they finished its work? Is there a vbs-command for it? Is there a way when calling "cmd.exe" with a proper parameter?
Martin Bohm
(5,261 Views)
Hello Martin!
For a 'good' solution you have to call the external program in a way that it will exit after finishing work. Another way - if implemented - is to start the external program as a OLE server.
If this isn't possible you have to be more violent. On Windows XP there is a small tool 'taskkill.exe'. Call this program with parameters wich will identify the external program (e.g. Programm name) and it will be aborted (no common exit!). Note I: You have to be shure that the work was already finished. Note II: This will abort all runing instances of this program!
Example 'taskkill.exe' call to 'exit' DIAdem:
C:\WINDOWS\system32\taskkill.exe /F /IM DIAdem.exe
See M$ help for parameter usage or use -? parameter
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(5,255 Views)
Thank you for the hint, it helps.
Is there a command to check if a certain program is still running?
Martin Bohm
(5,255 Views)
Hello Martin!
Yes, with the tool 'tasklist' in the same directory.
The problem is that it is not easy to query from script. I tried it in the following script. Perhaps not perfect espacially because a command interpreter pop up every time you call the function.
Option Explicit
If
IsDIAdemRunning() Then
Call
MsgBox(
"At least one DIAdem is running!" )
Else
Call
MsgBox(
"No DIAdem at all!" )
End If
Function
IsDIAdemRunning()
Dim oWshShell
Dim oExec
' Execute via Shell Object
Set oWshShell = CreateObject("WScript.Shell")
Set oExec = oWshShell.Exec(
"C:\windows\system32\tasklist.exe /FI ""IMAGENAME eq DIAdem.exe""")
' wait until tasklist is finished
Do While oExec.Status = 0
Pause(1)
Loop
' no Standard Output -> no DIAdem running
IsDIAdemRunning = Len(oExec.StdOut.ReadAll) <> 0
End Function
A better solution might be possible via WMI.
Matthias
Matthias Alleweldt
Twigeater?
(5,239 Views)
Hello Martin!
Now I had the time to look for the solution with WMI. You have to be shure that it is allowed/possible to use WMI on the target computer. This solution is faster and more reliable compared to the taskkill/tasklist solutions.
The script shows how to get the processlist for a specific EXE. It prints the count wich you can use to find out if a process is running and then termiante all running instances of this EXE.
Option Explicit
Dim
oWMI
Dim oProcessList
Dim oProcess
' Get WMI for the local computer
Set oWmi = GetObject("winmgmts:{impersonationLevel=impersonate}!\\.\root\cimv2")
' Query process list
Set oProcessList = oWmi.ExecQuery("Select * from Win32_Process Where Name = 'DIAdem.exe'")
' Print running processes count
Call MsgBox( oProcessList.Count & " DIAdem.exe instances are running")
' Terminate all runing processes
For Each oProcess in oProcessList
oProcess.Terminate()
Next
Matthias
Matthias Alleweldt
Twigeater?
(5,232 Views)
