DIAdem
How to automate Diadem using VB Script or LabView VIs
Thanks for your reply,in my case i have about 20 variables through which i have to get the data, so at a time i have to load 20 channels.but  You have send me a VI for getting XML configure string, i tried by that also, i have written that in script and run the script.it,s not loading the data in portal,every time we have to call the command "Call StorageImport" & after calling this command it's loading the data which was there in the portal previously.and if we are doing seperation in the script by using XML=XML &"", then alos it's not working, i am sending you an attachment where i have seperated the long script by "XML =XML &" while running the attatched script it's loading the data which was already there in the portal.
Message 11 of 17
(2,173 Views)
Can you please give me example of any one script, where seperation is provided in order to have VBScript  on one command line.because i tried by breaking the line by both of the methods, with "call storage import" command.it's not importing data into the portal
Message 12 of 17
(2,173 Views)
Hi 8,
Here's an example of concatenating with the "&" operator.
Brad Turpin
DIAdem Product Support Engineer
Message 13 of 17
(2,152 Views)
Thanks a lot for all your help,hope it will help me to sort out my problems.
Message 14 of 17
(2,147 Views)
Hi bro pls i need your help.. am female.. and need your support in citadel pls can you give me your jabber id so we can relate better.email; firstladylady2003@gmail.com thank u bro
Message 15 of 17
(1,392 Views)
Hi bro pls i need help.. am female.. and need your support in citadel pls can you give me your jabber id so we can relate better. thank u
Message 16 of 17
(1,392 Views)
Hi magabush,
Repeating your request is not going to make a difference.  You need to ask a clear technical question of the correct NI Discussion Forum.  This is the DIAdem Discussion Forum, so all we can help you with is loading desired data from a Citadel data base into DIAdem.
Brad Turpin
Message 17 of 17
(1,364 Views)
