DIAdem
How can I install DT300-measurement card in diadem, where can I get dt300.dac?
I had to install Diadem 8 and Diadem 6 again because of a computer porblem.
WE also got a DT-300 measurement card from Datatranslation. How can I use this card under Diadem?
I already installed the card under Windows XP, but I don´t have any dac-file of dt300!
(3,557 Views)
Hi Superb,
DIAdem 6 was shipped in 11/1998 and DIAdem 8 in 9/2001 that was before Windows XP released, so both revisions
don't support Windows XP for measurement. Additional DIAdem 6 doesn't support this hardware.
In general you must install first the DTOL driver coming from Data Translation and the you must register the GFSDTOL.DLL in the GPI-DLL-Regitration. Please have a look into the DIAdem help to get more info.
Greetings
Walter
(3,556 Views)
Thank You Walter for your advices.
Now I use Windows2000 for diadem. I got a Core-file for DT-300 but I don´t have a DTOL Driver!
In the GPI-DLL-Registration I can only register DTOL.dll.
But I can´t find the DT-300! I still try to find somethin under Diadem Help.
(3,533 Views)
Hi Superb,
with the Data Translation (DT) hardware you got the DTOL driver coming from DT. That driver must be installed first. Additional to the driver there is a small test program from DT. Please check with that program whether the hardware is running fine (if not you must contact DT). If it's working go ahead with DIAdem as described.
Greetings
Walter
(3,525 Views)
