DIAdem
Generate table of Y values at Specific X value
I have a chart with 8 plots. I want to generate a table of Y values for each plot at a specific X value. I have tried using event search, but cant figure out how to spit out what I need.
(3,325 Views)
Please show us your VI, or a simplified version of it. (actual VI, not a picture).
Is it a chart or a graph? What's the datatype?
("Event search" and "spit" are not typical unambiguous technical terms. No idea what they mean here)
(3,311 Views)
By "event search" I'm referring to the DIAdem function of "Event Search". I'm not sure how much less ambiguous I can be.
I'm working within a table and graph. Datatype is all numerical, no waveform.
I am just trying to say for X = 0.143, y = "?"
(3,271 Views)
Is the data sorted in x and do you want interpolation if the exact x does not exist?
(3,267 Views)
What is your function to generate the y channel (I can show example code)?  This sounds like a task for the "channel calculator" located on the top toolbar as a calculator icon
(3,262 Views)
The Y channel is not generated. Its brought in from a .txt file.
I was actually able to figure this out using Event Search (Free Formula), not just the regular Event Search.
I was needing Y values, for all X values equaling 0.255. My encoders are accurate to +/- 0.00001 which means I had a whole bunch of data points starting with 0.255xx.
I used A = (X channel)
(A>.254)^(A<.256). This got me everything that started with .255.
For result storage, my "condition fulfilled" was to use value from channel, which I selected as my Y channel.
Then I was able to select Mean, StDev, Max/Min from Characteristic Values and output new channels.
From there I just wrote a script that output those 4 channels from each of my 45 different data sets into Excel and made a chart there (as I couldnt get a pretty chart in DIAdem).
Hopefully this helps someone in the future.
(3,229 Views)
Hi Jacob,
Consider using the "Row = PNo(Xchannel, Xvalue)" function to return the "row number" for each curve that is closest to the Xvalue you specify.  Then you can request the "Yvalue = Ychannel(Row)".
Brad Turpin
Senior Technical Support Engineer
(3,186 Views)
