le 07-15-2005 01:42 AM
le 07-15-2005 02:01 AM
le 08-28-2011 12:44 PM
Hi effendie,
i am having the same problem. Could you share the solution you find?
Ignacio
le 08-28-2011 11:31 PM
Hello Ignacio,
Is there a reason why you would not use a DataPlugin in favor of the ASCII loading process?
DataPluings are very easy to create and easier to handle in Scripts as well.
Otmar
le 08-29-2011 08:24 AM
Hi All,
DIAdem 2011 no longer enables the GPI-DLLs used by the old ASCII Import Wizard and Excel Import Wizard. The replacement features are the ASCII DataPlugin Wizard and the Excel DataPlugin Wizard, and as Otmar mentioned, you will get much better performance and many extra features when using a DataPlugin.
If you need to continue using existing scripts that are based on either of these old features, all you need to do is go to the menu Settings>>Options>>Extensions>>GPI Extensions... and add the GfSAscii.dll and/or GfSExcel.dll to the list of active DLLs. After that you should save your Desktop.DDD file in order for the change to persists in all future DIAdem launches.
Brad Turpin
DIAdem Product Support Engineer
le 08-29-2011 09:07 AM
Thanks a lot Brad,
I changed the settings and it worked perfect 🙂
Ignacio
