DIAdem
Fullsize View+DP
is it somehow easily possible to display both view AND dataportal fullsize?, or do i have to make it all by "customizing diadem" ?
Thanks a lot
(6,237 Views)
Hi AndiMEC,
As far as I can tell, filling the entire screen with the contents of the VIEW panel exludes the Data Portal from being seen.
Brad Turpin
DIAdem Product Support Engineer
(6,223 Views)
Hi Brad_Turpin
Call WndShow("VIEW","FULLSIZE")
 doesn't include the Data Portal in my DD
Greets
(6,209 Views)
Hi AndiMEC,
I am agreeing with you, when I say that fullscreen "excludes" the Data Portal.  The fullscreen display hides everything but the contents of the panel you have active, and the Data Portal is also hidden along with the rest of DIAdem.
I don't see any way around that.
Brad Turpin
(6,181 Views)
Not sure if this would help, but you can make the DataPortal a "floating" dialog, and you could plate it anywhere on the screen. It's in the "Window" menu ...
Otmar D. Foehner
(6,167 Views)
