DIAdem
FormulaCalc error when using variablesin variable files?
I defined two variables RForce_ and IntLength_' in variables files:
as following:
IntLength_ : I <1700>
RForce_ : R <1.4314>
in vbs file,I have following:
Call FormulaCalc("Ch('PSA_Kraft') := ('RForce_'-'RForce_'/'IntLength_'*'Gurtweg')")
When I run the vbs file,diadem reports following error:
The formula
contains an invalid mathematical operation .. ('RForce_'>-<'RForce_'/'IntLength_'*'G.. with text!
When I don't use variables, as following:
Call FormulaCalc("Ch('PSA_Kraft') := (1.4314-0.000842*'Gurtweg')")
my vbs file can run correctly.
Anything wrong with my code?
(3,551 Views)
Hi Junwei You,
Yes, there is a problem with the formula calculator expression.  You need to use the ' character only when you are referencing existing data channels, not for VAS file variables.  Also, I strongly recommend that you always use the full Ch('ChannelName') construct when you reference an existing data channel.  Try this instead:
Call FormulaCalc("Ch('PSA_Kraft') := RForce_ - RForce_/IntLength_*Ch('Gurtweg')")
Note that you may need to insert further parentheses to specify the exact order of the / and * operators.
Brad Turpin
DIAdem Product Support Engineer
(3,536 Views)
