DIAdem
Find maximum value from a plot in DIAdem View
After I read some unclear posts that almost reached my need, all of them are saying in some way that DIAdem VIEW tab couldn`t acomplish, but they are from 2009. Maybe there´s something new.
I want to have a View Text window, where I can show the average, maximum and minimum values of a channel loaded on Data Portal. I can do this with CCh funtion, that's fine.
But here goes my doubt, is there a way to show in the Text window, the points mentioned above from a plot of a 2D system that would be on the same page of the Text window. I mean, instead of using the whole channel, I want to use the data on the graph so I could use zoom to measure (max, min and mean) from only a portion of the channel data.
If this isn't possible, could I get only the data zoomed on a 2D system and paste on a new channel, and then use the CCh function in Text Window????
Luis Padua
(6,175 Views)
Hello Luis,
This example might do what you are trying to do, I am not 100% sure, but figured it would be worth a shot:
It sounds like this might help you along ...The dialog that is floating with the statistics results could be embedded into the VIEW screen as well ...
     Otmar
Otmar D. Foehner
(6,172 Views)
Thanks Otmar for pointing out this example...
It is almost what I want, I will need to modify it a little bit. If I stuck into something, I'll be back on this post again...
Best Regards
(6,148 Views)
