DIAdem
Extract Order Data
I have engine data where I am measure pulsations in the fuel rails.  The data is collected with an engine RPM sweep from 700RPM to about 4500RPM. I am most interested in viewing the time domain amplitude within a certain order range.  For example, I would like to see only half to third order data.  I am currently using Digital filters, and only looking at a section of my data at a time, so I was wondering if there is any way to digitally filter data based on order, rather frequency.
Thoughts?
(4,416 Views)
Hi Russell,
DIAdem has several order analysis functions you can use for this-- though the ANALYSIS dialogs are only available with the DIAdem Professional version.  Have you tried the below posted application, which will work in any of the 3 DIAdem flavors?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x14vCAA&l=en-US
Brad Turpin
DIAdem Product Support Engineer
(4,399 Views)
Unfortunately, I do not have the professional version, and I use the linked program often (and learned how to do effecient rising edge detection with it, too).  I will try to convince my managment to purchase the upgraded version.
Thanks.
(4,395 Views)
