DIAdem
Exporting to PDF
Having an error in the way files are viewed after exporting to PDF.  I've used this report powerpoint for a long time without this problem.  On my new workstation, it was exporting to PDF as usual, then randomly (no settings were changed) it started looking like the attachment below - like all the text was squished together.  I tried going through the report template and resetting all the fonts to "Arial" which they were defined as before, using the PDFFontsEmbedded=1 command, with no success.
Anybody else run in to this, and what did you do about it?
(4,065 Views)
Hello rlodor,
Could you please let us know what version of DIAdem and what OS you use. It also helps to have some information about your PC (processor, RAM) to help narrow down the issue.
Have you installed any new software (even unrelated to DIAdem) before this problem started occurring. Anything from Adobe (new Reader for instance).
    Otmar
Otmar D. Foehner
(4,063 Views)
Running Windows 7, 64-bit
NI Diadem 2010
Intel Xenon 12 processor, 3.06ghz
12gb RAM
Adobe Reader 9, no changes to it, but I have adobe X I'm planning to get installed later this week hoping that might correct the issue??
(4,058 Views)
