DIAdem
Excel worksheet add after syntax
  I have a large application that creates a report following a test.  The report is about 250 pages, with each page represented as a group in the data portal.  When we deliver the report the customer also wants an excel file with the X-Y data pairs for each of the graphs in the report.  I know how to do the data selection and the copy/paste to excel.  Where I run into problems is when I am adding worksheets to Excel, I can't figure out how to direct the new worksheet to be added to the end.
According to the VBA info about Excel there are parameters Before and After that should allow you to do this.  I just can't figure out the syntax to include these parameters.  The line of code in question is in red.
If you have nothing but the .Add statement the code works but the worksheets show up in reverse order.  I have tried a number of different ways and the script just dies without even showing an error.  I know a work around which is to cycle through the list of groups backwards, but that just doesn't sit well with me.  I would prefer to do things in a logical manner being from first to last.
If there are any questions please let me know.
Thanks in advance.
Wayne
  FilePath = autoactpath & "\dataoutputtemplate.xls"
  ExOpen = True
  WorkBookName = NameSplit(FilePath, "N") & ".XLS"
  On Error Resume Next
  Set Excel = GetObject(,"Excel.Application") ' Get Excel via OLE if it is open already
  If Err.Number <> 0 Then
    Err.Clear
    Set Excel = CreateObject("Excel.Application") ' Start Excel via OLE
      'Exit Sub
    End If
    ExOpen = False
  End If
  Excel.Visible = true
  IsWorkbookOpen = Excel.Workbooks(WorkBookName) Is Nothing = False
  If ExOpen Then
    If Not IsWorkbookOpen then
      set ExcelWkb = Excel.Workbooks.Open(FilePath) ' Open Excel File if not open already
    End If
  else
    set ExcelWkb = Excel.Workbooks.Open(FilePath) ' Open Excel File since excel was not already open
  End If
  Err.Clear
  On Error Goto 0
  GrpStart = GroupIndexGet("Globals")
  NumGrp = GroupCount - GrpStart
  ReDim PageList(NumGrp)
  ReDim SectList(NumGrp)
  b = 1
  c = 1
  for a = GrpStart to GroupCount
    CurGrpName = GroupPropValGet(a,"name")
    If InStr(CurGrpName,"List") then
      SectList(b) = Mid(CurGrpName,5) 'Removes "List" from the Group Name to be used in the Table of Contents
      b = b + 1
    End If
    If InStr(CurGrpName,"_") then
      PageList(c) = CurGrpName     'Gets a list of groups that need to be exported
      c = c + 1
    End If
  next 'a (cycle through groups to gather names)
  'Add Table Of Contents Sheet to workbook
  Set ExTOC = Excel.Workbooks(WorkBookName).WorkSheets.Add
  ExTOC.name = "Table Of Contents"
  For d = 1 to c-1  'c is the number of valid sheets in the report that will be exported
    Set ExcelSht = Excel.Workbooks(WorkBookName).WorkSheets.Add (After:=Last sheet in workbook)
    ExcelSht.Name = PageList(d)
  Next 'd next report page to be exported
(9,497 Views)
Accepted by topic author waynecj7
Hello Wayne!
What you have to know is that you can leave parameters empty. The solution for your problem is:
Set ExcelSht = Excel.ActiveWorkbook.WorkSheets.Add(,Excel.ActiveWorkbook.WorkSheets(Excel.ActiveWorkbook.WorkSheets.Count))
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(9,488 Views)
Thank you very much.  I didn't see in the documentation I was looking at that there was another property befor "After".
I just tried it and it works perfectly.
(9,484 Views)
