DIAdem
Excel Add-In: COM Automation only as administrator?
as I tried to connect to TDM (see code below),  I've got the message that it need admin authorisation
Set obj = Application.COMAddIns.Item("ExcelTDM.TDMAddin")
obj.Connect = True
Is it really necessary to have Admin authorisation?
(7,792 Views)
As you see here, you need to start Excel in Admin mode once after the installation of the TDM Excel Add-In:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019VhwSAE&l=en-US
Hope this will help you.
Best wishes
Dennis
Work with NI Hard- and Software for about 15 years now.
Certified LabVIEW Developer & TestStand Developer/Architect
(7,749 Views)
With Excel 2013 in Windows 8 I have to do it everytime I open the file.
I believe it's due to compatibility configurations within applications that are not visible or tweakable for a user...
any thoughts or similiar experience?
thanking in advance,
Miguel
(7,107 Views)
hi,
I ended up by foundin the answer to my problem and came back to share it.
i used the TDM Excel Add-In: COM Automation example of NI.
Get TDM Excel Add-In
 Dim obj As COMAddIn
 obj.Connect = True
Just remove/comment the part
obj.Connect = True
(6,895 Views)
