DIAdem
Error localisation via script
is there any coding way to extract the exact position where an error occured in the script? You usually get the position and the script name displayed in the LogFile, but apparently this does not happen when "On Error Resume Next" is enabled.
What I am trying to achieve is that a message with all error information is being sent out as soon as an error occurs. Message sending works but the information I can currently grab are only Err.Description, Err.Number and Err.Source which does not help me very much as I cannot localise it.
Anyone with an idea?
/Phex
(6,349 Views)
Phex
Here is a link on Error trapping in VB script from the best person I know about for VB script.
http://blogs.msdn.com/b/ericlippert/archive/2004/08/19/error-handling-in-vbscript-part-one.aspx
Paul
(6,324 Views)
Hi Phex,
Within the On Error Resume Next ... On Error Goto 0 structure the Err object is available for reading and setting error states, like this:
Dim Result, ErrNum, ErrMsg, ErrSrc, Msg
Result = 9/0 ' questionable command line
ErrNum = Err.Number
ErrMsg = Err.Description
Errsrc=Err.Source
On Error Goto 0
IF ErrNum <> 0 THEN
  Msg = "Error occured"    & vbCRLF
  Msg = Msg & "Number = "  & ErrNum & vbCRLF
  Msg = Msg & "Message = " & ErrMsg & vbCRLF
  Msg = Msg & "Source = "  & ErrSrc & vbCRLF
  MsgBox Msg
END IF
I strongly recommend you surround only the select command(s) you expect might throw an error.  You'll cause yourself no end of trouble if you just turn on On Error Resume Next at the top of your script and never turn it off, or if you surround 20 or 30 lines of code with the error handling.
Brad Turpin
DIAdem Product Support Engineer
(6,255 Views)
Thanks for the input Brad, but it seems quite exausting to equip all probable error sources with a surrounding "On Error"-handling.
Do you know how DIAdem itself extracts the error information? I am particularly looking for that type of phrase e.g. "Error in <track_sub_20140113.VBS> (Line: 3260, Column: 3)"
/Phex
(6,252 Views)
Hi Phex,
I don't know how DIAdem extracts the error information.  Ideally you would not have that many possible error sources in your code.  Would it be possible to turn some of that error-prone code into a Subroutine and call it multiple times?  That way the error handling would just be in the Subroutine once.
Brad Turpin
(6,221 Views)
Hm.. Right now I do not see this working very well as even subroutines have gotten quite long occasionally and as per Murphy's law you will most probably do not get an error where you have expected it. I guess for the time being the best is to turn off error resuming completely and cross fingers that everything works - or if not then handle each error at a time based on DIAdem's location message and restart the script.
/Phex
(6,216 Views)
