DIAdem
Error al iniciar DIAdem 2018
22
33
11
Buena tarde, tengo el siguiente problema al intentar abrir el DIAdem salen los error que podrá estar pasando?
Good afternoon, I have the following problem when trying to open the DIAdem do the errors that may be happening?
(1,650 Views)
Hi jaime_guerrero,
Your DIAdem looks like it has been heavily customized.  I'm guessing from the errors you show in the screenshots that whoever you got this DIAdem application from has startup scripts that are failing.
What version of DIAdem is this, and who makes the "OBS-ONE Post Processing" tool that you're starting in these screen shots?
Brad Turpin
Principal Technical Support Engineer
NI
(1,614 Views)
