DIAdem
Dynamical Channel Selection
Hi people,
I use DIAdem 2011. I have a question on channel selection. I am calculating the mean of channels using the function "Call ChnAverage("'temp1'-'temp3'","mean")" and the input-list varies which means "temp3" could be "temp4" or "temp5". So I want to control the last input with a variable like tempi. But in "" DIAdem doesn´t recognize "i" as an integer but a part of string "tempi". Does anyone have idees to manage this problem? Thanks a lot!
Andi
(5,916 Views)
Hi Andi,
To answer your question, the correct syntax is:
Dim oMyAverGroup, i
i = 3
Call ChnAverage("'[4]/Temperature_1'-'[4]/Temperature_" & str(i) & "'","mean")
But I would prefer the Data-API. With that you create an object which contains all the channels you would like to be calculated. Then you have several options to collect these channels like:
Dim oMyAverGroup, i
set oMyAverGroup = Data.CreateElementList
' Option 1 - adding several channels
call oMyAverGroup.Add(Data.GetChannel("[4]/Temperature_1"))
call oMyAverGroup.Add(Data.GetChannel("[4]/Temperature_2"))
call oMyAverGroup.Add(Data.GetChannel("[4]/Temperature_3"))
' Option 2 - a wildcard (joker)
set oMyAverGroup = Data.GetChannels("[4]/Temperature_*")
' Option 3 - a loop
for i = 1 to 3
  call oMyAverGroup.Add(Data.GetChannel("[4]/Temperature_" & str(i)))
next
' run calculation
Call ChnAverage(oMyAverGroup, "mean")
Greetings
Walter
(5,911 Views)
Accepted by topic author A._Baumann
Thank you very much Walter. The ideas are brilliant
(5,898 Views)
I try to run the example but I'm graced with an error message "non permitted Channel names ??? in ChnAverage(???,"Mean"). Either of the 3 ways to add elements to the list 😞
simple check via
For Each oMyChn inoMyAverGroup
CallMsgBoxDisp(oMyChn.Name)
Next
shows that the names have been correctly added to the list. But ChnAverage (or other functions) do not work
Why would that be? Is it DIAdem2011 at fault?
Thanx for assistance
Michael
(5,742 Views)
Hi Michael,
It looks to me like DIAdem found no channels with the right name in the Data Portal and you are trying to loop over an empty collection.  The For Each construct unfortunately executes even if there aren't any elements in the stated collection.  Try "MsgBox oMyAverGroup.Count" before the loop.
Another possibility is that some of the channels you added might be string/text channels, which will not work in that average routine.  Could you please post your data set and the VBScript you're running?
Brad Turpin
DIAdem Product Support Engineer
(5,692 Views)
Hello, Brad
I think that I have found if not the solution, but at least the cause for the weird behavior: When running my script via F5 (or equivalent), the Channels collected via
                   Data.GetChannels(oMyChnGroup.name & "/*")
will be passed correctly to subsequent commands like
                 chnAverage
or
                DataBlDel(oMyElementList,....)
BUT
when I run the script stepwise through M$ script debugging via F8, even though
                msgbox(oMyElementList.Count)
shows the correct number of listed elements, the following commands will not receive correct channel lists, giving the "???" error message.
So, in a way, problem solved. Whether to pursue the issue of VBScript debugging, DIAdem2011 and win7 - I don't really mind...
Thank you.
Michael
I attach the script anyway. It's purpose is to separate different test stages, which are identified by integers in channel "Zyklusnummer", into a bunch of channel groups, one for each test stage. Unfortunately, the test stand supplier was unwillling to forsake his proprietary file format to change to TDM. Otoh, his file format supports more levels of hierarchy, i.e. subgroups, which makes it easier for him.
Option Explicit
dim i, iIndexstart, iIndexEnd, iNumZyklen
Dim oChnGrp, oNewChnGrp, oChannel,oMyWorkGroup, oMyChn
set oChnGrp = data.Root.ChannelGroups(1
set oMyWorkGroup = Data.CreateElementList
iNumZyklen = oChnGrp.Channels("Zyklusnummer").Properties("maximum").Value - _
             oChnGrp.Channels("Zyklusnummer").Properties("minimum").Value + 1
'msgbox(cstr(iNumZyklen))
iIndexStart = 1'Beim Aufspalten in Zyklen fangen wir "vorne" an
iIndexEnd = 1'und gehen davon aus, dass der erste Zyklus schlimmstenfalls 1 Wert enthält
for i = 1 to iNumZyklen
   set oNewChnGrp = data.Root.ChannelGroups.AddChannelGroup(oChnGrp) 'Kopiere die Originaldaten in eine neue Kanalgruppe
   oNewChnGrp.activate()
   oNewChnGrp.Name = oChnGrp.Name & "_Zykl_" & cstr(i) ' und einen "vernünftigen" Namen vergeben
   iIndexEnd = PNo("[1]/Zyklusnummer", i+1)-1
   if iIndexEnd < iIndexStart then
       iIndexEnd = CL(1)
   endif
   msgbox(" Zyklus: " & cstr(i) & vbCrLF & "Startindex: " & iIndexStart & vbCRLF & "Endindex: " & iIndexEnd)
' Jetzt kopieren wir die Kanalnamen aus der aktuellen Gruppe in die Elementliste
   set oMyWorkGroup = Data.GetChannels(oNewChnGrp.Name & "/*")
   CallDatablDel(oMyWorkGroup,iIndexEnd,CL(1))
   CallDatablDel(oMyWorkGroup,1,iIndexStart)
   iIndexStart = iIndexEnd + 1
next
(5,655 Views)
