DIAdem
Dynamic View with DIAdem 2011
Hi Near,
You should set the DisplayType property to be "CurveChart2D" before you can access the Graph elements.  Then if the Graph is truly empty, you must first create a new curve.
Set Sheet = View.Sheets("Sheet 1")
Set NewViewArea = Sheet.Areas(2)
NewViewArea.DisplayObjType = "CurveChart2D"
Set NewViewGraph = NewViewArea.DisplayObj
Call NewViewGraph.Curves.Add(XChannel, YChannel)
Brad Turpin
DIAdem Product Support Engineer
Message 11 of 14
(2,661 Views)
Thank you Brad !
When I try to display a channel from scratch using a script, I bump into the following error: "An invalid index was accessed."
Here is my code:
View.ActiveSheet.Cursor.Type = "Curve"
Set DisplaySheet = View.Sheets("Sheet 1")
Set DisplayArea = DisplaySheet.Areas.Item(1)
DisplayArea.DisplayObjType = "CurveChart2D"
Call View.Sheets("Sheet 1").Areas.Item(1).DisplayObj.Curves.RemoveAll
View.Sheets("Sheet 1").Areas(1).DisplayObj.Curves.Item(1).YChannelName = "ChannelName"
 Even when I replace the last line by this one:
DisplayArea.DisplayObj.Curves.Add("", 1)
 I get the following error: "Cannot use parentheses when calling a Sub". The problem is that I am not using any sub in the VBS file containing this code... I am feeling that the error is minor and only few characters should be corrected.
Message 12 of 14
(2,641 Views)
Actually do not bother anymore, I was forgetting a Call somewhere and it obviously took me hours to realize it........
I would be interested in the commands used to change markers and colors in VIEW, I'm sure a couple methods will do but I could not find the right one (especially for colors) while exploring this forum as well as the help. Edit: done
Message 13 of 14
(2,631 Views)
Hi Near,
I suggest you interactively configure the VIEW graph to show the markers just like you want them to look, then pop up the configuration dialog and hit <Ctrl-A> for DIAdem 2011 and older or <Ctrl-C> for DIAdem 2012 or newer.  This will put the whole contents of that dialog onto the Windows Clipboard.  If you then go to a script in the SCRIPT panel and hit <Ctrl-V>, you will get the following code:
Dim oCurveObj
Set oCurveObj = View.Sheets(1).Areas(1).DisplayObj.Curves.item(1)
oCurveObj.LabelChannelName        =""
oCurveObj.LabelIndexChannelName   =""
oCurveObj.LabelChannelOrientation ="horizontal"
oCurveObj.MarkerType              ="circle"
oCurveObj.MarkerLineWidth         ="min"
oCurveObj.MarkerSize              =2
oCurveObj.MarkerColorAuto         =true
oCurveObj.MarkerColor             ="black"
oCurveObj.MarkerColorRGB          =0
oCurveObj.MarkerFillColorAuto     =true
oCurveObj.MarkerFillColor         =""
oCurveObj.MarkerFillColorRGB      =0
oCurveObj.MarkerFrequencyMode     ="CalcNPoint"
oCurveObj.MarkerIntervalPoints    =1
oCurveObj.MarkerIntervalLength    =10
oCurveObj.MarkerAtBegin           =false
oCurveObj.MarkerAtEnd             =false
Brad Turpin
Message 14 of 14
(2,615 Views)
