I would like to know if there is a way to create a dynamic channel in DIAdem. I see the variable "ChnType" will tell if a channel is fixed or dynamic, but can I set a channel to be dynamic? I also need to know what DIAdem means by "dynamic" channel.
What I understand dynamic to mean is as follows: for example, ChnA = ChnB + ChnC. If ChnB or ChnC change values after calculating ChnA, ChnA will not update its value if it is a fixed channel, but will if it is dynamic. Is this type of dynamic channel availble in DIAdem?
Thank you!
Julia
