DIAdem
Double clicking TDM file opens DIAdem but does not load file?
Every other Windows program automatically loads the file when application opens.  Is there a setting for this?
NOTE:  Using DIAdem 10.2 on Windows Vista Ultimate 64 Bit and Windows XP Pro 32 Bit.
(3,692 Views)
Hi, CaliDevGuy,
As far as I know, there is not a way to load the TDMS file by double-clicking. The best you can get is load DIAdem, which you have accomplished already. Sorry about the inconvenience.
Song D
Application Engineer
National Instrument
Song Du
Systems Software
National Instruments R&D
(3,664 Views)
CaliDevGuy,
You can try this file. It will update your registry files. I tried it on my computer and it works. You can load it into registry by double-clicking it.
Song Du
National Instrument
Song Du
Systems Software
(3,636 Views)
Thanks.  That file did work fine in XP....
Unfortunately no luck in Vista 64 Bit Ult.
Any ideas?
Thanks again.
(3,611 Views)
